CA9 9mm Carbon Potentiometer Part File (Arduino Starter Kit)
OK here is a part with breadboard modified to look more like the picture. I expect pcb will be incorrect, but it isn’t clear which of the potential footprints in the pdf is the correct one, so if you want to put this on a pcb the footprint will likely need adjustment.
pot-arduino-starter-kit.fzpz (7.4 KB)
