I’m new to this but I’ve had a look around and can’t find much on this board. Hopefully this is enough information for someone to at least point me in the right direction. Thank you.
You’re pretty close, it does vary slightly with the boards I have.
I got the vernier calipers out and the actual board dimensions are around 15.6mm x 24.6mm.
If you add the 0.6mm down the middle of the board (between the power supply and outputs) it should be just about perfect.
