Bugs in Arduino Nano Every Fritzing part v6
Problems with the core parts can be reported in the issues for the github parts library repository.
There are 2 Arduino Nano parts in the core library.
Arduino Nano3(fix)
Arduino Nano3(icsp)
Both of those are Dated Feb 5 2020. Your “variant 7” (from the Help with building HmIP-MOD-OC8 - #8 by BastianF thread) is from someplace else.
According to the information I can find, the Nano has 2 RST pins connected together internally, so that bus seems to be correct, for the core parts. Your part looks a bit different, with Castellated connections, so I can not verify the pinout.
My “guess” is that when one of the core parts was used as a base to create that “every” variant, the pin numbers changed someplace, and the bus was not modified to match that. In addition to the other problems with terminal points and drill holes.
Where did you get that variant 7 “Every” part from? People here can fix a copy of the part, but it really should be (also) fixed ‘upstream’, so that someone else does not try to use the bad version.
