According to the information I can find, the Nano has 2 RST pins connected together internally, so that bus seems to be correct, for the core parts. Your part looks a bit different, with Castellated connections, so I can not verify the pinout.
My “guess” is that when one of the core parts was used as a base to create that “every” variant, the pin numbers changed someplace, and the bus was not modified to match that. In addition to the other problems with terminal points and drill holes.
Where did you get that variant 7 “Every” part from? People here can fix a copy of the part, but it really should be (also) fixed ‘upstream’, so that someone else does not try to use the bad version.
Here is a corrected part for the THT version (SMD version to follow). As usual the mounting holes in pcb are not drilled by default. If you want the mounting holes you need to drag a hole from core parts/pcb in t the sketch, place it over each of the mounting holes on silkscreen and set the appropriate hole size.
Please be carefully here, the Arduino Nano is a chip family as seen here. The “Arduino Nano Every” is pin compatible with the “Arduino Nano 3”, however its not the same Arduino.
So in my eyes the “Arduino Nano 3” you mentioned isn´t the “Arduino Nano Every”. The Chip Design is different and therefore might confuse persons, if the wrong picture is used for the nano every.
I have only v6 here which can be downloaded from the offical arduino page here. Here is a direct link to it. It looks like the same fritzing part file is also linked here.
That is where I was trying to “politely” start from. Your initial post did not contain enough information to identify which part had the problems.
The core parts actually have a family of “microcontroller board (arduino)”
And that is the detail that was needed to show which part has the problem. It also shows that the problem needs to be updated on the Arduino web site, so should be reported someplace over there. Maybe the forum https://forum.arduino.cc/, but I don’t spend time over there to be sure.
People working with Fritzing have no control over what is put on the Arduino web site.
@microMerlin all fine ;-). If you check my posting above more closely you can see that there exists already a link to the Arduino Github Repro (right now tagged as bug). But not every Fritzing user might find that there, as they might only search the Arduino board or the fritzing board (and not GitHub). So I decided to build a cross posting in the Fritzing board as for me, the buggy part caused some issue, which I couldn´t explain and which forced me to check the component. If I had routed the PCB automatically I wouldn´t recognized that (and would have ended with a non working PCB), it was only possible to detect that via the manual routing. So this posting here might be important for some other fritzing users as long as the buggy part is still out there . However I took your posting as reason to edit that and cross link the source page where I downloaded the v6 part from.
On top of that I would offer here my fixed version as reply, however @vanepp was always faster then I
@vanepp I think I will skip the mounting points. The idea was to solder in two rows of female push in connectors which can hold the nano every. But I appreciate the tip
