Bounty for Creation of a Part
Hi!
I’m willing to pay someone to create a part in Fritzing. Specifically, to start, I’m looking for the https://www.osepp.com/electronic-modules/sensor-modules/65-ir-follower#. Please reply with quotes, if you’re interested :smiley:
(P.S., mods, if I’m not allowed to request this in this forum, please politely reply and I’ll stop. Thanks)
This one may do what you want.
Thanks for the reference. I have a very crude understanding and usage of the part editor, at the moment. What’s the best way to go about adding the extra IR LED and associating pins?
I hadn’t noticed the 6th sensor. As parts creation is fairly complex the best bet is that I make the change (since I made the original.) It will be up in a while.
Thank you for your time!
This part should do what you want. Note I cheated a bit and set the analog pins to female (so they won’t connect to the breadboard and short) but the digital ones will (in real life they would short to the analog pins if you did that!) It is easy to change back if that isn’t desirable.
osepp-6channel-ir-follower.fzpz (27.5 KB)
Thank you so much, Peter! Looks great.
