Hello, I am currently in search of a BOSCH LSH25 electrochemical sensor to create a circuit schematic, however, since it is specific I am not sure how I can either find it or create it. It would be appreciated if I could get some help, thank you. P.S. This is the only picture I could attach of the oxygen sensor.
It should be easy enough to make a part. This web site appears to have the pin out and colors of the 4 wires:
https://www.lancerregister.com/threads/lambda-sensor-wire-colour.100967/#lg=thread-100967&slide=1
The question is do you want a particular connector on the end of it or would 4 wires do what you want? The connectors appear to depend on what type of car you are trying to connect it to, and it is unclear to me whether you are going to use this standalone (where 4 wires should do) or in a car which may need a connector (ion which case we would need the pinout of the connector.)
