Hi everybody,
I am currently trying to create a multi sensor on a nodeMCU (HW-625) running ESPHome. I had attempted this before, but eventually decided I’d start from scratch.
The device is currently powered via USB, but this can still be changed (if I need to, please tell me).
I want at least these sensors to be connected simultanesouly
- PIR Sensor (binary input)
- DS18B20 (dallas) OR bme280 (I2C)
- 2x door reed sensor (binary input)
- 1-2x push button (binary input)
- TEMT6000 (ADC)¹
- MCP23017 (I2C) (hardware: CJMCU-2317)
- 4x regular LED
¹ I want to use the TEMT6000 in most projects, but some will have another ADC component there (vibration sensor).
The previous hardware setup I had worked fine; unfortunately, after I ordered PCBs for this, there were two issues:
- while the PCBs were meant to hold
nodeMcu V3 CH340G), I must have downloaded a wrong template, as they did not fit and I had to usenodeMcu CP2102s, which are a bit more narrow and did fit= - once I connected the CP2102, nothing worked; I don’t know if this is due to the board itself, due to incorrect production (or design!) of the PCB, or insufficient power supply
I am currently connecting sensor after sensor, adding the software configuration, and am testing this step by step, but am already having issues.
When trying to flash, I have to disconnect VV and G (providing energy to the sensors), otherwise it will not flash. So either they are drawing too much energy already, or I cannot use them with this board - if so, which ones should I then use? VINand G did not work, and 3V and G only work for 3.3V sensors.
Considering that I have not even connected the MCP23017, I assume that I cannot use USB to power the board? If this is the case, what would be the best way to power it? I have some nodeMCU dev boards (from Aliexpress), that allow connecting 12V, plugging in the nodeMCU board, and powering it. I assume the dev board regulates power so that the nodeMCU only receives 5V; how could I do this on my own without using the dev board (it is pretty huge and I don’t need all the extra pins etc. that it offers, so I’d prefer a smaller DIY version of it).
Thank you for your ideas
