Tired to spend time getting all pins function definition from the manual, I extend adafruit bbb part with all the main functions of the pins
BeagleBoneBlack.fzpz (51.8 KB)
Is this supposed to be for a 2 sided board, because the top copper is missing for the PCB view. Some people use these to layout the shields, which are usually 2 sided.
Just put copper0(bottom) inside copper1(top) and all the nodes get repeated on the top.
If you want those 4 big holes drilled also put them in copper.
The general format these days is that you make a “silkscreen” layer with all the lines and text, and copper1 with copper0 inside it with the actual nodes that are critical, like contacts and holes…
