Hi all
I need help with a B8B-XH-A Connector being made. I find the parts editor confusing and cannot figure out how to use it.
Can anyone help with the making of a B8B-XH-A Connector for a PCB I need to design?
Hi all
A data sheet and the number of pins desired would be needed to make a part.
Sorry, I forgot to include it.
its the 8 pin one
Easy enough. Drag a connector in to the sketch in Inspector (lower right window) set the type to molex and the number of pins to 8.
that gives you the connector. Now drag a hole in to the sketch set it to 1.7mm diameter and move the hole to the correct place via the x and y tabs in inspector (note to get accurate results you need to zoom the pcb out as far as possible before setting the position.)
edit or use this part
B8B-XH-A.fzpz (4.8 KB)
done.
Thanks, I appreciate the help.
