Help with this IC CD4052
Part Name​:red_exclamation_mark:
CD4052 (4-Channel Differential Analog Multiplexer/Demultiplexer)
Your prior work, similar parts
Components from the CD4000 series exist in the standard library (such as the CD4051), but the specific CD4052 model is required with its respective dual analog pins (X, Y, channels 0–3).
Top View​:red_exclamation_mark:[Copy and paste an image of the CD4052 pinout diagram in DIP-16 format here. You can use a clipping from the datasheet showing all 16 pins]
The official manufacturer documentation for the part is linked here: https://www.ti.com/lit/ds/symlink/cd4052b.pdf
DIP-16 (for breadboard use)
[ ] I did not read this
[ ] Breakout board, sub-assembly, plug-in module (A)
[ ] Antenna (AE)
[ ] Battery (BT)
[ ] Capacitor (C)
[ ] Diode (D)
[ ] Display (DS)
[ ] Fuse (F)
[ ] Hardware, mounting screws, etc. (H)
[ ] Jack, fixed part of a connector pair, header (J)
[ ] Relay (K)
[ ] Inductor, Coil, Ferrite Core (L)
[ ] Speaker, Buzzer (LS)
[ ] Motor (M)
[ ] Microphone (MK)
[ ] Plug, movable part of a connector pair (P)
[ ] Transistor (Q)
[ ] Resistor (R)
[ ] Thermistor (RT)
[ ] Varistor (RV)
[ ] Switch (S)
[ ] Transformer (T)
[x] Integrated Circuit (IC)
[ ] Crystal, Oscillator (Y)
[ ] Zener Diode (Z)
[ ] Other (please specify)
Could you upload an example sketch with the component from the Fritzing library here? I can’t find the part you described as
I’ll see if i can dfind some info
