Dear Peter, Can you help me create a library of this tool?
I really hope for your help
replace part with one with the extra 4 pins on the bottom added.
auto-transfer-switch.fzpz (13.1 KB)
Hello peter, can you add the same number of output pins as the input pins as I have marked in the picture below
Done. You will need to remove the current part from your mine parts bin (by right clicking on it and selecting remove part) then shutdown Fritzing answering yes to both save part and save changes to bin. When you restart Frtizing you should be able to load the new part.
Thankyou very much peter
