Hello everyone, I have a problem with the Atmega644 DIP-40 part, which I believe, is a part of Fritzing’s core part library. If I place the part on the breadboard, then the contact area of pin 1 (PB0) seems to cover the whole IC, which makes it impossible to more the IC around:
Also, it also seems that some other pins (7, 10, 27, 31, 39) are broken: if I place the IC on a breadboard, these pins are connected to the board’s rails, but I cannot attach a wire directly to these pins.
I am a total newbie to fritzing, so I would really appreciate if someone with experience in fritzing part design could have a look at this part. Thanks in advance.
