Yes, that is the general idea for what I was talking about. Pin numbers are optional, and somewhat personal preference. Hovering over a pin will show the associated connector number, name and description. I usually use that, because I have run into parts with pins that are miss-labeled in one or more views. The pin descriptions can be wrong too, but at least I can tell what is the same pin in different views. Pin number labels do get a bit strange for bused connectors (see below). For that, a single schematic pin really connects to multiple physical pins, so choice for label is not obvious.
This example is a work in progress to develop an Arduino UNO (and other) board that is shield friendly. That is, a shield part placed on top of it will properly connect the matching pins, and show those connection on schematic and pcb views.
uno_test.fzpz (27.3 KB)
A few things in the current version of that are of interest here. First, there are 5 pins in the breadboard view that are GND. Click and hold on any one of them highlights all of the others, and wires connected to one are effectively connected to all (also highlighted). That is done using a bus in the part definition file. See Internal connections in the part definition file format.
Next, the part is a ‘board’, but the schematic is almost the same as the bare chip. Except for the ICSP2 header. This shows only a single GND pin. Since the connectors are all on the same internal bus, Fritzing understands that they are connected together, so in the logical / functional schematic view, only a single GND is needed.
There are a couple of ways to implement that. One (commonly used) is to create all 5 pins in the schematic view as normal, but place (stack) them all at the same place. It LOOKS like one pin. The bottom pins can be graphically invisible or not. Only the top one is actually seen. A better (I think) way, is to make the extra copies of the pin invisible in the svg, and mark them as hybrid
. See Hybrid connectors in the part definition file format. Only one connector on a bus needs to be ‘normal’ (in schematic view). PCB view as different constraints. There you want (if possible) to have every connector that does not have a pin representation on pcb to be hybrid.
That is less used (or understood). I added to the referenced documentation recently after research and experimentation to find what what the requirements were to make it work. Most of the examples I found were broken one way or another.
Next, the pins on the schematic view are grouped into blocks, similar to what you have already done. An extension to that, especially if you want to use functional names as pin labels, is to add a group label (and maybe bracketing line), to show that the set is all part of eg port B.
