Asking for part components
Does someone have the library for the ff components:
  • Pixhawk PX4 PIX 2.4 32 Bit Flight Controller
  • ATMega328 Arduino
  • TCS3200 Color Recognition Sensor
  • L298D Motor Driver
  • MPPT Solar Converter
  • MG958 Servo Motor
I’m fairly new so the only thing I can do is connect parts. I can’t make them due to its complexity and I need to have the breadboard diagram by Tuesday
A google search of form “fritzing part Pixhawk PX4 PIX 2.4 32 Bit Flight Controller” turns up this post from 2019. I doubt much has changed since then.
Similar google searches will turn up any parts that are available (some of them are in core parts in Fritzing as well so search in the parts search window.) Therr is a generic servo motor in core parts for instance and at least one DG servo that I remember.
Thank you so much! Hope I’ll finish this before Tuesday.
Assuming this is an assignment of some kind, I would advise checking that the appropriate Fritzing parts haven’t been provided somewhere. There may be a part for the flight controller that I haven’t found. It seems unlikely that the correct parts wouldn’t be provided.
