hello can i run a code using a esp32 here on fritzing? all i can see here is for arduino and picaxe
Fritzing, the application, or the web site, do not themselves run (or simulate) any micro-controller code. The application allows storing code in the sketch. If that is configured in Fritzing, and the related tool is also configured, the code will be compiled and loaded to an accessible micro-controller.
The ‘code’ view is intended to store sample code to run with a project sketch. For specific cases, it can act as the editor for the target micro-controller.
I expect other platforms could be supported. For systems that use drag and drop style python, it should be fairly easy. It would need just enough to identify the target device, then copy a file to it.
You can store code there even if Frtizing does not supply any support to run it.
thanks for the clarification my dude, can i still ask tho if there is a app or web that accommodates both of simulation and importing custom parts i’ve tried wowki but the devices are too limited i want to try it since my items is has not arrived yet and yk figure it while waiting for the parts i need
nvm i found a better 1 and its called cirkit designer it literally has all of the components i need so goated
