Is the STM32F405RGT6 also in the core parts?
https://www.mouser.be/datasheet/2/389/stm32f405rg-1851084.pdf
If not is it possible to add it?
Many thanks
Many thanks
Doesn’t appear to be one. You would need to specify what package you want to make one.
Hi Peter,
Package LQFP64 please
Gregory
That turned out easy. This part in core parts should do what you want. A quick look indicates the pin out is the same (I assume they are all identical.)
Fabulous
Thank you!
Sunny greetings
