Note pcb was created from a jpeg as I can’t find any connector placement information so it may not be correct. If someone who has a board would compare a real board to the pcb footprint and flag any errors it would be appreciated.
From your png above (which is better quality than the one I was working from), it looks like I was mostly correct in the placement in pcb (this is your png imported in to Inkscape and scaled then overlaid on the pcb svg.)
Hello Peter, and thank you for this Arduino UNO R4 WiFi part. We use it in many of our tutorials.
We found one small problem: all connectors in the part are male, also the 4 Uno headers. Fritzing connects two parts only male to female, so a shield or a screw terminal block dropped on the board does not connect to its pins. On the real board (and in the core Arduino Uno (Rev3) part) these headers are female.
We made a version based on your part with these changes:
the 4 Uno headers are female, so shields connect (ICSP, Qwiic, OFF/GND/VRTC and the ESP32-S3 header stay male)
pin names are the board labels (D0, D1, A0 …)
a new schematic with the pins on the 0.1 inch grid
same frame and connector IDs, so a sketch can switch to it by changing only the part
