Arduino Nano ESP32
I just got one and I can’t seem to find a fritzing part.
(ignore the double headers, there is only one per pin on the real one)
The datasheet is here: https://docs.arduino.cc/resources/datasheets/ABX00083-datasheet.pdf
These parts should do what you want. There is a tht (through hole) and smd version. To connect to headers use the through hole to solder it to a board use the smd.
arduino-nano-esp32-tht.fzpz (24.6 KB)
arduino-nano-esp32-smd.fzpz (24.5 KB)
