Hello all,
I am making a project schematic that requires the Arduino MKR GPS Shield (ASX00017). I did a bit of searching and couldn’t find it anywhere. I’m new to Fritzing, and I would make a part if I knew how. Thanks in advance to anyone willing to help me out .
This should do what you want. Due to poor documentation it would be a good bet to verify the pinout against an actual board though. The mounting holes in pcb are not drilled by default, if you want the mounting holes you need to drag a hole in to the sketch.
Arduino-MKR-GPS-Shield.fzpz (12.3 KB)
thanks ! Do you know how to simulate on Fritzing or convert that file to Kicad or Proteus ?
It won’t simulate on Fritzing as it has no spice model, and no I don’t know how it can be converted to Kicad or Proteus.
@vanepp thank you.
Its so good to see you helping everyone out with whatever it is. Thank you so much!! appreciate your hard work …
