APC340 Radio Communication Module
Hello everyone
I am currently working on a project with RF modules. I need to get the library for the APC-340 module to build the circuit in Fritzing.
The data sheet can be found at the following link:
Thank you so much
Sincerely, Gaston
There is a APC220 part available here.
The APC340 has two more pins which are both NC and the pins names more or less match. It should work unless you are looking for pcb to match in which case you would need a custom part.
I will try it
Thank you very much Peter
