AGPtek 60kg 130LBs Holding Force Electric Magnetic Lock
This is to add support Magnetic Lock starting with a common one for escape rooms.
Specifications
  • Lock Size: 80Lx37.3Wx23.3H(mm)
  • Armature plate: 74Lx32Wx11H(mm)
  • Holding Force: 60kg(130lbs)
  • Mode: NC (locked whilst power supply is operating), fail safe mode
  • Voltage: DC12V
  • Current Draw: 0.11A ~0.15A
  • Safety function: Built-in voltage spike suppressor
  • Opening Mode: 90 degree swinging door
  • Suitable For: Wooden Door, Glass Door, Metal Door, Fire Proof Door, etc.
  • Net Weight: 550g
file:
AGPtek_60KG_Magnetic_Lock.fzpz (3.6 KB)
Ref:
https://www.agptek.com/index.php/product/agptek-60kg-130lbs-holding-force-electric-magnetic-lock-for-door-access-control-system-electromagnet-fail-safe-nc-mode
