this worked before update ?
can anyone check for me
thanks.
not sure how to attach the downloadable version of this file ?
thanks.
right click (context menu) save image works fine for what you did.
Version 0.9.6 introduced a bug where svg images that contain numbers in ‘engineering’ format will not export. That svg has path coordinates with “e” in them. Line breaks added for easier viewing
d="m 448.78676,94.942024 c -0.006,3.175937 -0.12431,5.757126 -0.11769,8.947076
-9.3e-4,9.78325 -3.76837,20.78156 -17.71485,20.34425 -14.82371,0.65749 -17.71586,-10.56024 -17.71679,-20.34425 0.006,-3.1428 0.19061,-6.227435 -0.0804,-8.937495 L 60.049916,94.914495 c -6.19628,
-6.51e-4 -10.49218,4.741883 -10.49218,10.630855 l 0,480.79883 2.4414,0 c 1.07201,-0.32287 2.21308,-0.5 3.40039,-0.5 l 382.341804,0 c 0,0 14.92061,-1.11725 16.78516,4.46875 l 0.43945,18.38086 258.21098,0 c 6.1962,0 11.1855,-4.73993 11.1855,-10.62891 l 0,-492.51953 c 0,-5.888972 -4.9893,-10.6315 -11.1855,-10.630855 z"
changing "-9.3e-4" to "-.00093" (or just “0”, its small enough, and "-6.51e-4" to "-.000651e-4" (or 0) should fix the problem. I changed those to 0 in both the board outline and silkscreen. Which got a good contour with gerber export. Here is the fixed svg.
thank you. The Fritzing community rocks.
Export to pdf? All exports? Specific views? Specific sketches?
Your best bet is to file a bug report on github here
with a copy of the .fzz file (or a simpler .fzz file to make reproduction easier) with screen shots as above of the current behaviour and screen shots from 0.9.4 which show the desired behaviour.
