Untitled Sketch 3.fzz (97.7 KB)
I exported the image in SVG format, but why do the ADS1115 and USB disappear? How can I fix it, or could you help me fix it and then send me the file? Thank you very much!
Yes, this is a common problem with parts (early on, my own included), the SVG content [EDIT: of the breadboard component of the part file] needs to be encapsulated in a group named “breadboard”. The attached parts should fix that problem (that’s all I changed though, so if there are other problems, this simple change will likely not have fixed them).
Adafruit ADS1115 16Bit I2C ADC.fzpz (17.6 KB)
USB A Plug.fzpz (10.7 KB)
(You may need to delete the versions of these parts that you currently have installed before loading these)
This still cannot export to SVG format
It worked for me… Have you deleted the old parts?
Yes, after I deleted the original, downloaded, and imported the file you sent me, exporting to SVG still couldn’t display it. But for now, I export it as a PDF first, and then converting it to SVG can barely be used. Thank you. It might also be an issue with my software version; I am using 0.9.9.
Okay, thank you for your help.
