I am having problems with the microprocessor part, ESP8266 NodeMCU LoLin module-fixed. I want to add this part to my parts bin, however the microprocessor part, ESP8266 NodeMCU LoLin module is already in the bin.
When I try to import the microprocessor part, ESP8266 NodeMCU LoLin module-fixed into my bin, I get the error message/dialog box informing me that the microprocessor part, ESP8266 NodeMCU LoLin module is already in the bin.
How can I remove the microprocessor part, ESP8266 NodeMCU LoLin module from my parts bin?
and yes to the save parts bins question (to actually delete the part!) This deletes the part and on restart Fritzing will allow you to add the new version.
You are correct it violates the principle of least astonishment . The problem is that the files are held internally so they are available to be either saved or discarded at the shutdown prompt. I have suggested a way to fix this (remove the deleted files from the list and actually delete the files when the user requested them) which would avoid the need to do the shutdown, but it hasn’t been implemented yet (likely due to more important bugs of which there are plenty!)
