Good afternoon! Can you please tell me where can I find DEVMO 8-32V to 45-390V DC-DC High Voltage Boost Converter ZVS Step-up Booster Module in the Fritzing Element Library? Information about DEVMO 8-32V to 45-390V DC-DC High Voltage Boost Converter ZVS Step-up Booster Module Amazon.com ](https://www.amazon.com/DEVMO-45-390V-Voltage-Converter-Step-up/dp/B07T6L61D9). Thanks in advance!
This part should do what you want. Note there is only a board outline in pcb (in case you want to mount the unit on a pcb) as the screw terminals won’t connect to pcb.
devmo-45V-390V-boost-converter.fzpz (10.8 KB)
Thanks a lot! This is what I need!
