Good afternoon! Can you please tell me where can I find a KF301-5.0-2P in the Fritzing Element Library? Information about a KF301-5.0-2P (Amazon.com). Thanks in advance!
Try core parts. Note if you need the pcb footprint you would need to check that the ones in core parts match the parts you have (and if not you would need a custom part.) Enter “screw terminal” in the parts search and press enter.
If that doesn’t do the job, then a google search of the form “fritzing part KF301-5.0-2P” may find a part someone has created.
edit: In fact you need a custom part as the holes in the core part are too small. This should do what you need
kf301-5_0-2p.fzpz (4.4 KB)
Thank you, it is what I need!
Hi, I am looking for KF301-8P (5mm pin spacing) - 8 pins.
Thank you.
This part should do what you want. As always before ordering boards print the pcb footprint out at 1:1 scale and compare it to a real part.
kf301-5_0-8p.fzpz (6.6 KB)
Thank you Peter. Works perfectly!
Thank you for your great support.
New member but I’ve been using Fritzing on and off for a few years.
I’m looking for a 2 pin screw terminal kf301 part.
I downloaded and opened the one above. It opens to 8 pin but when I set it to 2 pin it just closes Fritzing.
Any ideas?
Cancel that. I didn’t see the 2 pin 5.0 above. It works.
