Good afternoon! Can you please tell me where to find a K-type thermocouple in the Fritzing element library? I found the MAX6675 board for connection. Thank you in advance!
This is likely as close as there currently is.
found via a google search of the form “fritzing part type k thermocouple” which in general is the way to find parts.
Thank you very much! Tell me, please, can you make a thermocouple with two outputs (with dimensions corresponding to the actual physical dimensions for breadboarding). I am interested in just such a thermocouple as in the first figure on this site https://how2electronics.com/industrial-thermometer-max6675-thermocouple-arduino/
This should do what you want.
edit: replace with a part with different colors and pins in pcb as requested below.
nozzle-bolt-style-thermocouple.fzpz (4.7 KB)
Is it possible to make the square pin on the printed circuit board be “-”, and so that on the layout view there are red “+” and blue “-” wire pins instead of red and yellow?
