Add current transformer to fritzing
Hi All cant seem to find a current transformer to my PCB drawing.
new to fritzing and not sure what to do.
The part im looking for is below.
1
regards
Dennis
A google search of the form “fritzing part current transformer” indicates this post may do.
If not you would need a custom part and to make one we would need a data sheet with connection information and physical dimensions of the exact part you want (mostly so pcb assuming you want that is correct.)
A little late coming to the party, but I spent the last couple of days building this part: ZMCT103C. New to the forum so not sure whether I can (or even SHOULD) just upload the fzpz, but here goes nothing.
CT_ZMCT103C.fzpz (6.2 KB)
N.B. the pins are on 11.8 mm spacing so I had to bend them out a bit for the breadboard view. Also I set the pcb view pads to 11.8 mm on center, but have not actually made a pcb, so have not tested whether the spacing is accurate. It looks very close though.
Well it wasn’t close enough. I fixed the 11.8 mm spacing in Inkscape, plus then had to remove the reference in the XML to axial_lay_2_400mil_pcb.svg which was snapping to a .1" grid for the copper etching causing misalignment with the metric system.
CT_ZMCT103C_v2.fzpz (6.2 KB)
