SABUOT
November 5, 2023, 3:40am
1
Hello forum, I am new and I am looking for this piece, if you have it or you can create it, I would be appreciated, it would be the AD633 /low cost analog multiply.
vanepp
November 5, 2023, 4:42am
2
There doesn’t appear to be a custom part for this so your best bet would be to use a generic IC as in this post
Schematic in this part is lacking a lot of pins. A better job can be easily done by editing a generic IC
[capture]
If you drag in a generic IC, set it to 14 pins then click Edit pin labels you can set names for the various pins. You could also make a custom part but that is more complex (and no one appears to have done so yet.
[capture1]
