name and manufacturer of the part: AD623-SOIC8 / ANALOG DEVICES
Views: (breadboard / schematic / pcb)
Single Supply, Rail-to-Rail, Low Cost Instrumentation Amplifier
https://github.com/ccadic/AD623-SIOC8[details=Summary]AD623-SOIC8 / ANALOG DEVICES
Easy to Use
Higher Performance than Discrete Design
Single and Dual Supply Operation
Rail-to-Rail Output Swing
Input Voltage Range Extends 150 mV Below Ground
(Single Supply)
Low Power, 575 mA Max Supply Current
Gain Set with One External Resistor
Gain Range 1 (No Resistor) to 1,000
HIGH ACCURACY DC PERFORMANCE
0.1% Gain Accuracy (G = 1)
0.35% Gain Accuracy (G > 1)
25 ppm Gain Drift (G = 1)
200 mV Max Input Offset Voltage (AD623A)
2 mV/8C Max Input Offset Drift (AD623A)
100 mV Max Input Offset Voltage (AD623B)
1 mV/8C Max Input Offset Drift (AD623B)
25 nA Max Input Bias Current
NOISE
35 nV/√Hz RTI Noise @ 1 kHz (G = 1)
EXCELLENT AC SPECIFICATIONS
90 dB Min CMRR (G = 10); 84 dB Min CMRR (G = 5)
(@ 60 Hz, 1K Source Imbalance)
800 kHz Bandwidth (G = 1)
20 ms Settling Time to 0.01% (G = 10)
APPLICATIONS
Low Power Medical Instrumentation
Transducer Interface
Thermocouple Amplifier
Industrial Process Controls
Difference Amplifier
Low Power Data Acquisition
[/details]
