Hello! Could you draw the AC motor in the Fritzing application based on the photos I provided? This motor is the AC motor of a 3-phase frequency-controlled circulation pump. It is a 220 Volt, 180 Watt synchronous motor.
To make the motor we would need a data sheet with mechanical dimensions and connection information (photos aren’t overly useful.) The motor driver has a data sheet and should be doable.
Done. The original part has been replaced with an updated one. You will need to delete the current part and close Fritzing (to complete removing it) before you will be able to load the new part.
The motor is life size (as most Fritzing parts are.) It is possible to make one smaller but to do that I would need to know what size you want the motor.
