A blank board showed up when the PCB Gerber file was uploaded to multiple 3D gerber viewing website with absolute nothing on it. Is this normal? Can I still send this pcb to the producers for production?
It looks like there is a transform in the bottom layer which misplaces it. I’ll try and figure out what is going wrong.
Turned out to be operator error. I had multiple boards in the gerber directory and loaded the wrong copper1 layer, the real pcb looks fine so there is likely something wrong withthe viewer you are using. Also are you aware that the push button is SMD? It is also available as through hole which given the rest of the board is through hole may be what you want.
It appears to be. It could be cleared up and simplified some but it passes DRC and appears to create correct gerbers and so should create a correct board.
