Welcome to the forum. Pretty good parts. Fewer issues than a lot of the existing core parts.
I ran those parts through FritzingCheckPart. Here is a summary of what it reported, with my notes from manual inspection added. The information is the same for all 3 parts.
There are ‘px’ units on font-size attributes in the schematic view svg files that Fritzing is known to not handle well. The text size can change from what was intended. Fritzing wants just numbers, without units.
The new convention is to use black graphics for pcb silkscreen. It used to be white instead. The “#f0f0f0” color being used is not correct either way. Fritzing automatically converts (and so does the FritzingPartsCheck tool), but for future reference, black is preferred in the silkscreen of pcb svg files.
The part definitions do not include terminalId attributes for the connector schematic view entries. The connector pins you have defined (linked by the svgID attribute values) should be the terminalId instead, and the svgId should link to a 0.1 inch long line that has one end at the existing connector element. The lines are already there. Just need to move the id="connector«number»pin" svg attributes from the polygon to the line, replace it with id="connector«number»terminal", and add terminalId="connector«number»terminal" after the svgId attribute for the schematicView in the fzp file.
(for r894x-2A, connector 1)
<line stroke="#787878" y1="7.5599999" y2="7.5599999" x1="0.34999999" x2="7.5500002" style="stroke-linecap:round" fill="none" stroke-width="0.75" id="connector1pin"/>
<polygon points="0.001,7.897 0.001,7.21 1.113,7.21 1.113,7.835 " gorn="0.36" style="fill:none" id="connector1terminal"/>
<schematicView>
<p svgId="connector1pin" terminalId="connector1terminal" layer="schematic"/>
</schematicView>
Connector pin numbers should start at 0, and go up from there, instead of starting at 1. The pin names and descriptions can be anything, and do not need to match the numbers.
The breadboard svg files are missing the “breadboard” layerId specified in defintion files. The first (outer) group element in the svg files needs to have an id="breadboard" attribute.
The schematic svg files are missing the “schematic” layerId specified in defintion file. A group element is needed to wrap the graphical contents of the file, with an id="schematic" attribute.
A separate note. Where did you get the pin numbers and sequence? Typically, a DIP (dual inline) package part is numbered like IC’s. Start in the corner (top left or bottom left depending on orientation), then increment along that side, and back along the other side.
