Good afternoon! Can you please tell me where can I find 7-Segment LED Display, 4-Digit 0.56" Anode Red for Oven Timer Control in the Fritzing Element Library? Information about 7-Segment LED Display Ultra Red Common Anode 4 Digit 0.56" Customized 7segment Led Display For Digital Oven Timer Control - Buy 7 Segment Led Display,Customized 7segment Led Display,Digital Oven Timer Control Product on Alibaba.com. Thanks in advance!
There doesn’t appear to be one. It is easy enough to modify one to match, but the data sheet lacks the pitch (space between pins) of the pins. It appears to be slightly smaller that the typical 0.1in, but that may just be an artifact of scaling the jpeg image to match the dimensions. Assuming you have one of these do the pins fit in a 0.1in breadboard?
Here is a part, as noted the pin spacing is probably wrong as it was done from a jpeg image.
7-SEGMENT-4DIGIT-LB40569AR1S.fzpz (5.9 KB)
Thank you very much)) ![]()
