Hi guys, i’m building a mahjong score with four 7 segments 6 digits.
I’ve found the fzpz of the led 7 segment display with 4 digits, but I’d like to simulate it with one with 6 digits.
I would like to know if there is any way to simulate with 6 digits before going to the real model.
Thanks
There doesn’t appear to be a part for a 6 digit LED display. If you have the data sheet for one that you want to use it is relatively easy to make a part for it. There appear to be 6 digit modules available like this one (there are probably others as well.)
https://www.amazon.com/0-56in-Segment-Display-Module-Digital/dp/B0B1PTB7MK
I am not clear what simulate means in this case. If you want it to run in the simulator (which is spice based) the Fritzing part would need a spice model for the part you pick.
