I’m looking for a 5 x 20 mm glass fuse holder fritzing part for which the attached spec sheet applies. Anyone able to avail or create?
Rgds
Dick
This is an easy one
, search core parts for fuse and the one with fuse and handler (where I think they meant holder) appears to be what you want. The hole sizes and spacing in the gerber drill file match at least (I didn’t check the silkscreen though).
Thanks Peter, just as I want to recall the request I got your response. Indeed, a different search phrase brought me at the HTC-15 with spec sheet http://www1.cooperbussmann.com/pdf/d5543d84-3b93-45e2-afde-4a74ca0255f9.pdf
This one indeed also has a pin distance of 22,6. Hence, perfectly suitable for my application. Bingo!
Thanks as usual.
Rgds
Dick
