4s BMS
Does anyone know where can i get this 4s bms ?
4s BMS
@Isoe Attach the website of the part. You deleted the entire template (and I’m not happy)
My bad, here’s the link 4S 12V 120A Board with Battery Balance Board R2M31381 | eBay
Still not enough information, and I need the dimensions and a good front view (flat image) of the part
bms-5s-balancing.fzpz (19.4 KB)
Possible for you to modify from here? I just dont need the C- and B4 port.
I need the website with dimensions for the modification
alright, i got this pic for the initial bms i was asking for. The dimension is 56x86x14mm and the view of bms inside this picture is all i have. sorry bout that
This web site (which is presumably where this image came from) gives the information @RAPTOR7762 needs to make a part for this.
and is the information he is looking for. There are appropriate images in the description section of this web site for making a part.
12V 120A Board with Battery Balance Board R2M31381-fixed.fzpz (33.0 KB)
@Isoe This should be the part you want. Note that PCB suppressed as not useful
@Isoe Apologies the part above has issues. I’m correcting it now
@Isoe Edited post above
alright thank you so much !!!
