Hello. I need help on creating a part. I have found some similar components but they differ in design. Can anyone make a sketch for this?
The images are not good enough to make a part.
I found the description of the part in ebay
Finally a seller stated the connectors!
I hope this is the correct part
Ok, I haven’t found an image that has the top view of this part
Top view images on google (at least at my side) show the wrong part !
If you have the part with you, is it possible to take a good quality picture of the top view and post on the forum? This makes making Fritzing parts a lot easier.
Saving the image he posted then doing a google lens image search for the image turns up this site which looks to have sufficient information to make a part:
https://www.amazon.ca/Universal-Wireless-Control-Receiver-Transmitter/dp/B07WBZKV4G
specifically this image
which gives a flat image of the part and the wiring.
Are you planning on making a part for this? If so I won’t.
Hello! Here is the top view part I’ve found. I think the connector is just the same as the one you’ve posted.
433MHz Wireless Remote Control Switch DC 12V 10A RF-fized.fzpz (9.6 KB)
Here’s the part you should want.
I would like to thank @vanepp for helping me fix up this part!
Thank you very much. Your work is much appreciated.
