40-pin FPC adapter part request
(Adafruit) 40-pin FPC to Straight 2x20 IDC Female Socket Header
Since there is no official PDF-datasheet, I hope the informations are enough:
Official documentation from Adafruit
It isn’t useful as a Fritzing part. There are no FPC connectors on any Fritzing part that I am aware of so it won’t connect to anything and thus isn’t worth making. It could be done it just doesn’t appear to be useful.
Hey Peter, I need a breakout board like this for my current project. I’m not interested in the connection on the FPC side. It’s more about connecting the connector on the other side to a microcontroller (several components are connected in between). I need this for my documentation, so it would be great if someone could create this component. I also found a few FPC adapters for Fritzing online, but the respective pins were always designed for a specific (inappropriate) function or there weren’t enough connections.
Then the fpc connector here should do what you want.
The connector in breadboard is not dual row but all the connections are there.
FH12-40S-0.5SH.fzpz (14.1 KB)
