Looking for a 3-Pin XLR Male and Female Part for Breadboard. There are both in the library but they are designed for PCB and the connections are not visible for the breadboard, from what I can tell.
The connections are present in breadboard.
not so correct in schematic but close enough to not worry about.
There are 4 connections with this XLR I need a 3 pin xlr: pin 1 ground, Pin 2 hot, Pin 3 negative. This was made, seemingly, with a fourth connection to the XLR exterior, not sure what that is and why.
Presumably a connection to the outer shield. Ignore it if you don’t need it.
