Hi.
Does anyone know what this is called, please?
I’ve tried looking in the parts bin and the nearest I can see is called a Molex-1x3 Lock but the pins are not in a straight line whilst those on my part are.
Thanks.
Hi.
Thanks.
You want a 3 pin generic connector set to molex. Breadboard is a standard header, but pcb should be correct.
drag a connector in to the sketch then in Inspector (the lower right window) set the appropriate parameters.
Thank you, Peter.  I keep forgetting that there are options available to all the parts.  I just keep looking at the pictures.
I’ll try harder.
