CamdenBoss CTB93HE
3.81mm 90º pluggable screw terminal PCB male socket.
Male socket datasheet
Female plug datasheet
In 3.81mm there seams to only be sockets with sides, and that means if you mount them side by side there has to be a 5.2mm pitch gap between socket groups, ie 2 - two pins sockets side by side will have a pitch of 3.81mm, 5.2mm, 3.81mm.
3.81mm 2pin
3.81mm CamdenBoss Plug Socket - 2.fzpz (8.1 KB)
3.81mm 3pin
3.81mm CamdenBoss Plug Socket - 3.fzpz (9.3 KB)
3.81mm 4pin
3.81mm CamdenBoss Plug Socket - 4.fzpz (10.0 KB)
3.81mm 5pin
3.81mm CamdenBoss Plug Socket - 5.fzpz (12.0 KB)
3.81mm 6pin
3.81mm CamdenBoss Plug Socket - 6.fzpz (21.1 KB)
3.81mm 7pin
3.81mm CamdenBoss Plug Socket - 7.fzpz (14.4 KB)
3.81mm 8pin
3.81mm CamdenBoss Plug Socket - 8.fzpz (14.7 KB)
3.81mm 9pin
3.81mm CamdenBoss Plug Socket - 9.fzpz (15.1 KB)
3.81mm 10pin
3.81mm CamdenBoss Plug Socket - 10.fzpz (18.1 KB)
3.81mm 11pin
3.81mm CamdenBoss Plug Socket - 11.fzpz (18.3 KB)
3.81mm 12pin
3.81mm CamdenBoss Plug Socket - 12.fzpz (17.9 KB)
