I tried to create this part and check it with the help of Peter’s tools. I hope all errors are now fixed.
3.2 inch Touch Screen.fzpz (11.7 KB)
Regards Harald!
Regards Harald!
Afaik Peters tool did not get updates since a very long time.
Please consider use the fzp_checker.py scripts from the fritzing-part repo instead.
You’ll need to download the whole repo. The fzp_checker.py is just a wrapper to call the scripts that resides in the script/checker directory.
Calling the script without params or with --help option should give some usage instructions. Let me know if there is anything unclear with the script.
Good evening,
I checked the part with the new tool and found and fixed a lot of errors. Thanks again for the help. I’ll gradually check all the parts I’ve created with it.
Here is the cleaned-up version (Unfortunately I can’t remove the old one)
LCD_9341_3_2_zoll.fzpz (12.0 KB)
Regards, Harald.
