Hi Fritzers,
i’m totally new to fritzing and also electronics. What i’m trying to achieve is to connect 24x N-Mosfets to a 50 pin cable jack. Basically only 48 pins of the jack are in use.
No matter what i try, each time i horribly FAIL in terms of wiring and overlapping the wires…
Maybe any tip/advice from you pro-fritzers?
Thanks in advance
