230V Socket Outlet Part
Broco 15410 16A 250V
please help, how can i find a part that similar ?
thanks.
@mrbond1945
Closest
thanks for your reply,
but i need like picture i attach… for 220-250 V,
could you make this part? thanks
@mrbond1945 If they are electrically identical it should be fine. It looks to be the same except for the lack of GND
Do you need it for a presentation of some sort?
Edit:
@mrbond1945 Please provide the dimensions of the socket
Yes, I need for presentation and report…
The dimension 54*54mm.
Regards…
A part is now being made
@mrbond1945 This should be the part you want
edit (vanepp)
changed the schematic label from 120V to 230V and did some other part cleanup. So please download the this new part.
230V_Outlet.fzpz (2.9 KB)
hi RAPTOR7762, thank you very much.
the picture is very amazing.
but sorry, if you would please change 120V to 220V, this will be a question because I use 220V voltage.
regards
@mrbond1945 can @vanepp can you help me? I’m curently busy with a part request
@mrbond1945 Chanrged and replaced the part with a corrected one.
@vanepp & @RAPTOR7762 thanks you very much…
