Has anyone designed a part for the 21700 battery size?
Like this:
https://www.aliexpress.us/item/3256803018092489.html?gatewayAdapt=glo2usa4itemAdapt&_randl_shipto=US
Or this:
Thanks!
Like this:
Or this:
Thanks!
It is unlikely there is a part and we would need a data sheet that gives dimensions and physical layout (which are not on either of these sites!) to make one. There are some keystone ones on digikey that have data sheets though.
Hi thanks for the response, you make a good point and i apologize for that.
Here is a link to a datasheet that if possible I would like to use.
This should do what you want. As always before ordering boards print the pcb footprint out at 1:1 scale and compare it to a real part.
keystone-1124-21700-battery-case.fzpz (16.5 KB)
