Hi!
Does anyone have this relay for the fritzing? Or know where can I find it?
Thanks!
2 Channel Relais Modul 12V
Hi!
Thanks!
Peter, thanks a lot! It is undoubtedly what I was looking for!
Many thanks!
Hi Peter,
Any chance to have exact same module with 4 channels as well?
I do not. There is one available here (found by a google search for “fritzing part 4 Channel Relais Modul 12V”
http://omnigatherum.ca/wp/?p=338
if that won’t work I would need a web site with the details of the board you want to make one.
Hi, thanks. I will check that out later. For the info about the relay, no much detail can be found, but for sure the 2ch module could be used as a base (i guess).
That is perfect! Thank you so much.
