looking for a part similar to this
This should do what you want. As usual if you want the mounting holes (which will not be drilled by default) in your sketch you need to drag the hole (from core parts/pcb/hole) over the mounting holes in silkscreen and set the hole size appropriately.
OLED-display-2.43in-SSD1309.fzpz (4.7 KB)
