Hi all,
Anyone can help me to create 1N5400 - 1N5408 diode part. I have tried all the diode on fritzing and the internet but I found the terminal for 1N5400 - 1N5408 is greater than 1mm which is not fit with 1mm TH.
I have measured and refer to datasheet the terminal is ±D1.3mm. So anyone can please help me to create the part which is the opening is fit with the diode terminal?
Refer below the datasheet for 1N5400 - 1N5408 diode:
Thank you.
This part should do what you want. Pcb hole size has been increased to 0.06in (slightly larger than 1.3mm.)
Correct the case size and pad spacing (pcb and breadboard) to 0.5in
1n5400.fzpz (4.9 KB)
Hi @vanepp
The part you sent me is great. The opening actual is good with 1N5400 diode.
But I think it will great if you do it on 500 mil spacing causes my diode cannot fit into the hole.
Thank you.
My apologies I didn’t check the case size or layout. I have replaced the part with a corrected one.
This would not be overly helpful for this part, but I sometimes place a second via after the diode to be able to accommodate different sizes, should design or availability change.
