CIs there a 12:1 Step-down Transformer (Jensen JT-DB-E)? I have a data sheet, but I do not have access to make the part. Here is the data sheet if anyone is willing to give it a go. https://www.jensen-transformers.com/wp-content/uploads/2014/08/jt-db-e.pdf
https://www.jensen-transformers.com/wp-content/uploads/2014/08/jt-db-epc.pdf
Are you looking for the pc mount version, the wire version or both?
edit: Since the pcb version should work for either case here is a part that should do what you want (the pcb version)
transformer-jt-db-epc.fzpz (4.9 KB)
Both would be great. Thank you for responding.
As noted the part provided will do for both. The wires should fit in the holes for the pcb (which would be the only difference between the parts.)
